How to get Khmer ( Cambodian) bible when only PDF available
Discussion in 'General Questions' started by Freebox202, Jul 7, 2015.
  1. Freebox202
    Freebox202 New Member
    I'm trying to figure how to get the Khmer bible on to this app. I have it on the old app and it works great. When I go to download it, the only option is a PDF or you can click it and read it online in I guess html. Any to export form original app?
    Post #2 by niall, Jul 10, 2015
  3. niall
    G'day Freebox202,
    The new Equipd will only work for Bibles in ePub format. Even if you could convert the pdf version into ePub it most likely would not be recognised by Equipd unless you did a bit of tweaking.
    On the Equipd Bible page (http://www.equipd.me/bibles/) Matt states:
    "If you are technically minded, you can always generate your own EPUB files to load into Equipd. Be sure to use one of the EPUB files listed above as a template to start with, as the EPUB must conform to certain rules in order to work in Equipd."​
    Exporting from the original app: I don't believe this is possible, and I doubt that Matt would do that, as it would breach the Terms and Conditions that the Society has set.
    Your only option is to wait for the Society to make it available in ePub format.
    Hope that helps.
    Regards,
    Niall
