Bug Report Scrolling Not Working in Single Bible View
Discussion in 'Bug Reports' started by William Hurley, Nov 1, 2023.
  1. William Hurley
    William Hurley New Member
    I am using ios 17.0.3. After downloading the latest version of Equipd Bible today, I am not able to scroll the NW Revised in Mandarin Bible in Single Bible view. If I add a second Bible and then remove it, I can scroll again. But, if I select another chapter or book, the scrolling is disabled again. Do I have a setting incorrect somewhere?
    Hi @William Hurley so sorry to hear this is happening. Can you clarify what device you are using? Are you able to send me a screenshot recording / video? You can email it directly to support@equipd.me if you like. Sorry to hear this is happening.
  3. Glenn
    Glenn New Member
    I am having the same problem with my IPad Pro version 17.1
    When I open Equipd all looks fine but when I choose a book and verse it will show up but when I try to scroll, the screen just bounces back rather then scrolling down,
    Thanks for reporting this. I have managed to replicate the issue and think I have the fix. Shame it was not picked up by myself or my beta testers much earlier. If either of you are keen to be a beta tester please email support@equipd.me and let me know.
    Just waiting on Apple to confirm the beta for testing so I can proceed from there.
    In the meantime, maybe show 2+ Bibles so that you can at least look at the verses you need to read. Thanks for your patience.
