Fixed Window View not resizing verses box
Discussion in 'Bug Reports' started by Aniana, Nov 12, 2023.
Tags:
  1. Aniana
    Aniana New Member
    How can I widen the view of each Bible?
    It is only showing one line at a time when I
    scroll. See attachment.
    Hi @Aniana! Thanks for filling out the bug report.
    So this has been happening for some users, and most have managed to fix the issue by deleting and reinstalling the app.
    But...
    We may have found the actual cause. Can you try something for me? Can you go into the app, click the button top/left and go into the Settings > Bible Settings ... is "Show Picker on Double Tap" turned on or off? If it is "off", can you turn it on and see if that makes a difference?
    Please let me know how you get on.
  3. TAKARA TANAKA
    TAKARA TANAKA New Member
    Hi,
    I'm a long time user of equipd. And my case has happened a week ago. The verse displaying line has become only one line. Just same as @Aniana. I have no idea how to get it back. And I have tried "Show Picker on Double Tap" turned on or off. " yet, that makes no difference.
    You'd kindly let me know how I fix it.
    Hi @TAKARA TANAKA
    Sorry to hear you are having the same issue. I heard back from Aniana directly - toggling the "Show Picker on Double Tap" did indeed fix the issue for her.
    Other users have found that the only way to fix the issue is to delete the app and reinstall it. Please make sure you take a manual backup first.
    I hope that helps.
  5. TAKARA TANAKA
    Thank you for your advice.
    Now I started EQUIPD for the first time in a few weeks, it strangely returned to normal, though I didn't configure anything. Anyway, problem solved. ^^);
