Weekly Bible Reading 2024
Discussion in 'Contributed Schedules' started by iMatt, Dec 29, 2023.
    This is the Weekly Bible Reading Schedule used by Jehovah's Witnesses for 2024.
    How to Install - Option 1 (easiest):
    • Open the Schedules screen in the app.
    • Click the settings icon (top/left).
    • Click "Download and install new Schedules".
    • The internal browser will open - locate this page and click the ZIP file to install it.
    How to Install - Option 2 (old method):
    • Download the attached file "weekly2024-schedule.zip" in Safari.
    • Locate the downloaded file in the Files app > Downloads folder.
    • Tap+hold on the ZIP file and from the popup menu choose to "Share" to the "Equipd Bible" app. Note: If you do not see the Equipd Bible app in the "Share" list, then click on "More" to show additional apps and select it.
    • The Bible app should open, and you should get a message saying that the schedule was successfully installed.
    • You will then see the schedule listed under "Downloaded Schedules" inside the Bible app.
    • Make sure you set the Study Week for the Schedule (typically the day after your midweek meeting).
  2. DvD
    Thank you, Matt
